Creating the Patch
Create the chamfered1 patch using a polygon.
![](../../../../images/feko/getting_started_guide/patch_antenna_gps/image_patch_view_top.png)
Figure 3. Top view of the chamfered patch. Note that the face is set to perfect electric conductor (PEC) by default (PEC is indicated by the colour orange).
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
The example considers a left-handed circular polarised GPS patch antenna on a finite substrate.
Calculate the input reflection coefficient and circular components of a left-handed circular polarised GPS patch antenna on a finite substrate close to 1.57 GHz.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Create the model geometry using the CAD component, CADFEKO.
There are several options available to launch CADFEKO in Windows.
There are several options available to launch CADFEKO in Linux.
Use macro recording to record actions in a script. Play the script back to automate the process or view the script to learn the Lua-based scripting language by example. Macro recording allows you to perform repetitive actions faster and with less effort.
Set the model unit to millimeters.
Define variables to create a parametric model.
Define a lossy frequency-independent dielectric with a relative permittivity () = 5.6 and a dielectric loss tangent () = 0.0041 to be used as the patch substrate.
Create a finite substrate1 by creating a cuboid. Set the region of the cuboid to the medium, ceramic.
Change the region property of the substrate to dielectric.
Create the feed pin using a single line element.
Union the geometry (feed_line, patch and substrate) to create a single geometry part. A single geometry part will ensure mesh connectivity when the model is meshed.
Change the surface property of the patch to perfect electric conductor (PEC).
Voltage sources and discrete loads are applied to ports and not directly to the model geometry or mesh. A port must be defined before a source or load can be added.
Specify the frequency range of interest. For this example continuous frequency sampling is used where Feko automatically determines the frequency sampling for optimal interpolation.
When the frequency is set or local mesh settings are applied to the geometry, the automatic mesh algorithm calculates and creates the mesh automatically while the GUI is active using default mesh settings. When required, these mesh settings may be modified.
Refine the mesh locally at the chamfered edges
Add a far field request to the model.
Deactivate the macro recording of the model, inspect the resulting Feko Lua script and use the script to recreate the model.
The CADFEKO macro recorded Lua script for Example 3 is given below.
Save the model to a CADFEKO.cfx file.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
Display the model as well as the results using the post-processor component, POSTFEKO.
This example showed the construction, configuration and solution of a left-handed circular polarised GPS patch antenna on a finite substrate.
The example considers the antenna placement of a GPS patch antenna on a quadcopter.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
The example considers the transmission and reflection coefficients of a waveguide power divider.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
Point-entry allows a variable or named points to be entered by pressing Ctrl+Shift+left click on a variable or named point in the model tree.
