The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in
CADFEKO.
Union the geometry (Cuboid1 and Cuboid2) to create a single geometry part. A single geometry part will ensure mesh connectivity when the model is
meshed.
Voltage sources and discrete loads are applied to ports and not directly to the model geometry or mesh. A port must
be defined before a source or load can be added.
Refine the mesh locally at the waveguide port faces. The faces for the waveguide ports require a finer mesh to represent
the highest mode that should be taken into account. The higher order modes are typically evanescent modes.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated
automatically for all voltage and current sources in the model.
This example showed the construction, configuration and solution of a waveguide power divider. The model consists of a
hollow cuboidal sections with a cylinder (pin) in the centre. The near field and input reflection coefficient was calculated
and displayed.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
ports require a finer mesh to represent the highest mode that should be taken into account.
In the 3D view, select the three waveguide port
faces.
From the right-click context menu, select
Properties.
On the Modify Face dialog (Meshing
tab), specify the following:
Select the Local mesh size check box.
Set the Mesh size to
lambda/20.
Figure 1. The Modify Face
(Meshing tab) dialog.
Click OK to apply the properties and to close the
dialog.
Figure 2. Note the localised mesh refinement at the waveguide port
faces.
Note: The icon in the details tree indicate that
a local mesh setting is applied.
