Changing the Waveguide to a Shell (Hollow) Part
Change the solid waveguide part to a shell (hollow) part with metal walls.
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
The example considers a left-handed circular polarised GPS patch antenna on a finite substrate.
The example considers the antenna placement of a GPS patch antenna on a quadcopter.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
The example considers the transmission and reflection coefficients of a waveguide power divider.
Calculate the transmission and reflection coefficients of a waveguide power divider.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Create the model geometry using the CAD component, CADFEKO.
There are several options available to launch CADFEKO in Windows.
There are several options available to launch CADFEKO in Linux.
Set the model unit to millimeters.
Define variables to create a parametric model.
Create the power dividing pin using a cylinder.
Create the waveguide sections using two cuboids.
Union the geometry (Cuboid1 and Cuboid2) to create a single geometry part. A single geometry part will ensure mesh connectivity when the model is meshed.
Use the simplify tool to remove redundant faces.
Create a single geometry part from the waveguide and power divider pin to ensure mesh connectivity when the model is meshed.
Voltage sources and discrete loads are applied to ports and not directly to the model geometry or mesh. A port must be defined before a source or load can be added.
Specify the frequency range of interest.
Add a near field request to calculate the fields on a surface through the centre of the waveguide.
Refine the mesh locally at the waveguide port faces. The faces for the waveguide ports require a finer mesh to represent the highest mode that should be taken into account. The higher order modes are typically evanescent modes.
Save the model to a CADFEKO.cfx file.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
Open POSTFEKO from within CADFEKO.
This example showed the construction, configuration and solution of a waveguide power divider. The model consists of a hollow cuboidal sections with a cylinder (pin) in the centre. The near field and input reflection coefficient was calculated and displayed.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
