Example: Cable Reference Direction - No Installation
Consider an example where a cable path is created, but with no geometry present in the model.
The Cable reference direction is defined normal to a fictitious ground (in the “up” direction). No twist angle is defined along the cable path.
Figure 1. Specify Cable reference direction with no geometry in the model.
- dotted green line: vector
- dotted blue line: vector
- solid dark blue line: cable reference direction
- No bonding impedances are allowed in the harness, for example, no
termination / interconnect
circuit connections to the installation.
- All paths should at least have two signals in the outermost problem to create a return path.
- All paths in the harness should have an orientation vector defined (if that path does not have any nearby geometry / installation).
Figure 2. Cable harness and schematic view with cable reference direction set.
