Weave Definitions for a Braided Cable Shield
CADFEKO supports two methods to specify the size of the apertures for a braided shield layer.
The optical coverage for a braid indicates how visible the apertures are, where 0% is completely open (no shielding) and 100% is a completely filled (approximating a solid shield). The optical coverage and weave angle are coupled by the fill factor (F) for a braid, which is a quantity between 0 and 1.
Figure 1. Illustration of the braid parameters for a braided shield layer.
The fill factor (F) is calculated from the optical coverage using the following equation:
(1) F=1− 100−OpticalCoverage 100
where the optical coverage is between 0% and 100%.
The coupled equation for the fill factor from the braid parameters is:
(2) F= nmd 2πDcos(ψ)
where D is the mean braid diameter (outer radius of the shield minus half the thickness of the braided layer).
Optical Coverage
For the optical coverage definition, a minimum optical coverage is specified. The minimum optical coverage relates to the largest aperture size or minimum shielding that CADFEKO tries to achieve when optimising the braid for maximum coverage, by varying the weave angle.
Weave Angle
A nominal weave angle and deviation is specified for the weave angle definition. The optical coverage is calculated for the range of weave angles to represent the size of the apertures (using the braid parameters defined for a braided layer).
Note: As the weave angle changes, the shield diameter also changes depending on the weave angle and other braid parameters.
