Defining a Single Conductor Cable
Define a single conductor consisting of a core with an optional outer coating.
On the Cables tab, in the
Definitions group, click the
Single Conductor icon.
Figure 1. The Create Single Conductor dialog. -
Under Core, from the Metal
drop-down list, select one of the following:
- To create a PEC core, select Perfect electric conductor.
- To create a core consisting of a predefined metal, select a metal.
- To create a core consisting of a metal, which is not yet defined in the
model, click the
icon to define a metal or add a metal from the media library.
- Under Core, in the Radius field, enter the cable radius.
Under Insulation layer (coating), specify the
following:
- To remove the coating, clear the With insulation check box.
- To add a coating, select the With
- To add a coating consisting of a predefined dielectric, select a dielectric.
- To add an insulation layer consisting of a
dielectric, which is not yet defined in the model, click the
icon to define a dielectric or add a dielectric from the media library.
- Under Insulation layer (coating), in the Thickness field, enter the layer (coating) thickness.
- In the Label field, add a unique label for the single conductor.
- Click Create to create the single conductor and to close the dialog.
