ADAPTFEKO Options
Specify ADAPTFEKO command-line parameters using the GUI.
- Restart analysis number
- This option can be used if the run was discontinued and the temporary files were not deleted. Restart the solution at the number of the first incomplete analysis number.
- Delete temporary files
- This option allows you to delete the temporary files created during the
ADAPTFEKO run.Tip: Uncheck this check box to allow resumption of an interrupted run.
