Excluding a Part from the Model and Solution
A geometry part (or mesh part) that does not contain any ports, sources or loads can be temporarily excluded from the model without having to delete the part.
- In the model tree select the geometry part (or mesh part) that you want to exclude from the model.
- From the right-click context menu, select Include/Exclude.
The excluded part is hidden in the 3D view. The part is not (re)meshed and is excluded in the mesh info dialog.
An excluded part is indicated by the
icon in the model tree.
