Creating an Anisotropic Medium (Ferrite)
Create a ferrimagnetic medium. The medium is described by the permittivity and permeability tensors where the static magnetic field is orientated along the U axis, V axis and N axis respectively.
                On the Construct tab, in the Define group, click the
 Media icon. From the drop-down list, select the
 Anisotropic (3D) icon.
Figure 1. The Create Anisotropic Dielectric dialog (Polder tensor). - In the Tensor type field, from the drop-down list select Polder tensor (ferrites).
                Specify the magnetic properties.
- Under Medium properties, in the Saturation magnetisation (Gauss) field, enter a value for 4 Ms.
 - Under Medium properties, in the Line width (Oersted) field, enter a value for ΔH.
 - Under Magnetostatic bias field, in the DC bias field (Oersted) field, enter a value for H0.
                        Under Magnetostatic bias field, from the
                                Field direction
                            drop-down list, select one of the following:
- X directed
 - Y directed
 - Z directed
                Specify the dielectric properties.
- In the Relative permittivity field, enter a value for εr.
 - In the Dielectric loss tangent field, enter a value for tanδ.
 - In the Label field, enter a unique label for the ferrite medium.
 - Click Create to create the anisotropic medium and to close the dialog.
