Edge Ports
Apply an edge port to an edge between two sets of faces.
Faces referenced in the port definition must belong to the same part for a valid port definition.
Figure 1. The edge port in the 3D view. The side of the positive faces is indicated with a red cylinder and the negative faces with a blue cylinder.
