Solving a Curved Face with Faceted UTD
To solve a model with the faceted uniform theory of diffraction (faceted UTD), you must activate faceted UTD for each relevant curved face.
  1. Select the face(s) in the 3D view or in the details tree that you want to solve with UTD.
  2. In the details tree, from the right-click context menu, select Properties.
    Figure 1. The Modify Face dialog (Solution tab).
  3. On the Face properties dialog, click the Solution tab.
  4. Under Solve with special solution method, from the drop-down list, select Faceted uniform theory of diffraction (UTD).
  5. Click OK to save the face properties and to close the dialog.
