Network Schematic View
The network schematic view is a panel that shows all general networks, transmission lines and ports (wire and edge ports) in the model. Use this view to connect general networks, transmission lines, ports and loads.
On the Home tab, in the Create View group, click the  Schematic icon. From the drop-down list select Network Schematic icon.
Figure 1. An example showing the network schematic view with connections between transmission lines, general networks and ports.
Connect two elements by clicking on the connector point (indicated by a white dot) and dragging the connection until the mouse cursor is over the desired second connection point. When clicking on the second point, a connection between wires is indicated by a black dot.
Selected networks, transmission lines, ports and connections are indicated by a dotted outline.
Delete an element by selecting the respective element and pressing Delete.
