Moving the Display of the Far Field Origin
Move the display of the far field origin to be more consistent with the location of the source.
Far fields are displayed in POSTFEKO around the global origin. When the source of the radiator is located away from the origin, the far field origin can be moved to show a more intuitive result.
  1. Select the 3D view and far field result that you want to modify.
  2. On the 3D View contextual tabs set, on the Result tab, in the Rendering group, click the  Offset icon.
  3. On the Set display offset dialog specify new values for the U, V and N coordinates.
    Tip: You can use Ctrl+Shift+left click to click on the new origin for the far field.
    Figure 1. A dipole and PEC structure with a far field with no offset (on the left) and a far field with an offset (to the right).
