Supported File Formats for Import
POSTFEKO supports the import of native file formats as well as Touchstone file format.
On the Home tab, in the
File group, click the Import icon.
From the drop-down list, select the file format to import.
The following file formats are supported for import:
- Feko far field (*.ffe)
- The .ffe file is imported automatically. No further user input is required.
- Feko near field (*.efe, *.hfe)
- When a near field is imported, specify whether an Electric near field file
(*.efe) file or Magnetic near field (*.hfe) file or
both files are to be imported.
Figure 1. The Import data: Feko Solver near field dialog.Note: The .efe file and the corresponding .hfe file must have identical file names. - Touchstone (*.snp)
- The .snp file is imported automatically. No further user input is required.
- Report template (*.xml)
- A report template in XML format can be imported.
- POSTFEKO graph file (*.pfg)
- This file format contains the relevant information used during optimisation. This file type works in conjunction with the .pre and .cfx files.
- Custom data file
- When importing custom data, an import template needs to be defined.
