The GEMM database addresses one of the key challenges of DEM simulation: getting suitable material inputs for accurate representation of bulk materials.
The GEMM database contains thousands of Multi-Sphere material models representing a wide range of materials such as rocks, soils and ores. It is particularly suited for engineers in the mining, construction and agriculture industries who design heavy equipment handling such materials.
Users can take advantage of the huge wealth of material information within the GEMM database to see example materials and download input decks to use in their EDEM simulation just by answering 3 questions about the Bulk Material and one question about the Equipment Material.
To use the GEMM Database right click on either the Bulk Material or Equipment Material section of the Creator Tree and select the Open GEMM Wizard option. Note. The GEMM Database only contains Multi-Sphere models and cannot be used in conjunction with the Polyhedral or Sphero-Cylinder Solvers.
The first page is a description of the database, read, select “Search by Material Properties” and choose Next to answer the 3 questions on the particle Bulk Material behavior. Alternatively, to retrieve a bulk material you have already searched for you can select “Search by Material Name” and enter the ID number of that GEMM material:
Medium friction is designed around a material such as Steel. The material friction is based around an Inclination Test. A sample of the Bulk Material is placed on a flat plate, the plate is then inclined until the material begins to slide. A material with a low Bulk Material angle of repose will slide at a lower inclination angle than a material with a high Bulk Material angle of repose. As such, the Bulk Material is characterized as Low Angle (Repose Angle less than 35 degrees), Medium Angle (Repose Angle Greater than 35 degrees but Less than 45 degrees) and High Angle (Repose Angle Greater than 45 degrees). The Geometry Interactions are then provided based on the table below.
Material Type |
Geometry Type |
Static Friction (p-g) |
Rolling Friction (p-g) |
JKR Cohesion (p-g) |
Inclination Test Results (average angle) |
Low Angle |
Low Friction |
0.3 |
0.15 |
0 |
21 |
Low Angle |
Medium Friction |
0.45 |
0.15 |
0 |
27 |
Low Angle |
High Friction |
0.7 |
0.15 |
0 |
34 |
Medium Angle |
Low Friction |
0.45 |
0.15 |
0 |
28 |
Medium Angle |
Medium Friction |
0.7 |
0.15 |
0 |
35 |
Medium Angle |
High Friction |
1 |
0.15 |
0 |
39 |
High Angle |
Low Friction |
0.7 |
0.15 |
0 |
37 |
High Angle |
Medium Friction |
1 |
0.15 |
Low |
46 |
High Angle |
High Friction |
1.7 |
0.15 |
High |
49 |
(c) 2022 Altair Engineering Inc. All Rights Reserved. |
