List of fixed issues
1. All machines
Winding environment – Some inputs are not reminded
The inputs 'Inter-wire space" and "Twist" are not displayed in the datasheet view of the winding design context (ref.: FXM-14062).
This issue has been corrected.
Usage of Motor factory becomes extremely difficult
The usage of Motor Factory becomes extremely difficult when all the tests are performed and all of them are saved twice
This is mainly due to the management of memory. An increase the allocated memory for Motor Factory can solve the problem (ref.: FXM-13359).
Air inside empty slots is not well managed in the outer rotor topology
While exporting a topology with empty slots in outer rotor machine, the air inside the slots is attributed to the region "AIR" which is a moving region in outer rotor machine model. Thus, the model computation is not possible.
A workaround must consist of creation of a static air region called "AIR_STATOR" and to assign the empty slots at this region (ref.: FXM-13771).
2. Induction machines – Motor Factory – Test environment
Display of flux density
The display of flux density (isovalues) was wrong for induction machines with squirrel cage (ref.: FXM-14128).
3. Part Factory
Bad displaying of part in Part factory
While building a “part” from a corrupted Excel file, a dialog box without any message gets displayed. The warning indicates the origin of the issue (ref.: FXM-14067).
