In batch mode, a language command or script is passed as an argument to be executed in batch mode (no GUI, no window)
by the interpreters supported by Compose.
The Compose Notebook is a web-based implementation of Compose’s OpenMatrix Language (OML) into a Jupyter Notebook. Notebooks (see www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
Use the Signal Viewer to import and treat (basic) signals in both time and frequency domains, as well as generate
signals based on the most common waveforms such as step, chirp and sawtooth.
Run Compose in Batch Mode
In batch mode, a language command or script is passed as an argument to be executed in batch mode (no GUI, no window) by the interpreters supported by Compose.
Run Compose Light
Use the Compose Light mode when you want to work within a customized GUI without the display of the entire Compose interface.
