Finite Antenna Arrays
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Create the base element (antenna) and create a linear, planar, cylindrical or circular finite antenna array with ease. Add custom antenna array elements to create complex and arbitrary finite antenna array structures.
The DGFM solver considers the self-coupling, mutual coupling and the edge effects of the finite array, but only uses the computational resources equivalent to solving the base element.
Note: The base element encompasses all structures in the model when creating a finite antenna array (except for infinite planes).
