Creating a FEM Modal Port
Apply a FEM modal port to a flat face on the boundary of a FEM region.
On the Source/Load tab, in the
Ports group, click the
FEM Modal Port icon.
Figure 1. The Create FEM Modal Port dialog. -
Specify the port position using one of the following workflows:
- Specify the faces. Under Specify port, click as a list of faces and use point-entry to add the faces.
- Specify the face using three points. Under Specify port, click as points and specify the three corner points of the rectangular-shaped port.
- In the Label field, add a unique label for the FEM modal port.
- Click Create to create the FEM modal port and to close the dialog.
