This section presents the hardware configurations required for Altair
Flux 2D, Skew, 3D and PEEC & FluxMotor
2022.1.
Processor
The processors required to run
Altair
FluxMotor should have the following characteristics:
Element |
Characteristics |
Processor |
- Intel or AMD
- 64 bits
- multi-core
Minimum configuration (hard disk and RAM)
The minimum configuration required to run
Altair
FluxMotor are:
Flux 2D & FluxMotor |
Flux Skew/3D |
Flux PEEC |
Hard disk |
250 GiB |
500 GiB |
50 GiB |
RAM |
8 GiB |
16 GiB |
16 GiB |
Recommended configuration (hard disk and RAM)
The recommended configuration required to run
Altair
FluxMotor are:
Flux Skew/3D |
Flux PEEC |
Hard disk |
500 GiB |
1 TiB |
100 GiB |
RAM |
16 GiB |
64 GiB |
64 GiB |
Graphic card for Altair
Flux
The graphic cards required to run Altair
Flux 2D, Skew, 3D and PEEC should have the following
characteristics:
Element |
Characteristics |
Graphic card |
- OPENGL V2.0 compatible for an optimal graphic quality
(see below)
- NVIDIA chipset recommended
Altair
Flux uses the OPENGL V2.0 graphic technology. This technology
provides improved rendering and smoother motion when moving objects.
This technology requires:
- the use of a graphic card compatible with OPENGL V2.0
- the latest version of the graphic card driver supplied by the
manufacturer
A summary of the conditions of use is presented in the table below:
Conditions of use |
Installation of a graphic card compatible with OPENGL
V2.0:
- NVIDIA GeForce 6200 and higher
- ATI Radeon X1300 and higher
Installation of the latest version of the card driver
Warning: The use of graphic chipsets with shared memory is not
recommended.
It is preferable to use graphic chipsets with dedicated
memory.
