Silent Mode
Introduction
A silent mode installation installs Altair Flux 2022.1 without requiring any user interaction. The installer makes use of a response file that contains the installation options to run the installation from start to end without any user input.
Silent Mode
- Create a response file. Run the installer in interactive mode with the
r option to save the installation properties to a
response
file.
[INSTALLER_NAME] -r "[RESPONSE_PATH]\installer.properties"
- Trigger a silent mode installation from the command line using one of the
following options:
- Use the default property values as provided by the installer
package.
[INSTALLER_NAME] -i silent -DACCEPT_EULA=YES
Important:- Setting -DACCEPT_EULA=YES means that you accept the terms of the License Agreement and allows you to proceed with Altair Flux installation
- If nothing is specified for ACCEPT_EULA variable or if -DACCEPT_EULA=NO then Altair Flux will not be installed
- Specify
properties.
[INSTALLER_NAME] -i silent -D[Property]=[VALUE]
For example:
-DACCEPT_EULA=YES -DUSER_INSTALL_DIR=/home/<username>/2022.1/altair
- Use a response file containing
properties.
[INSTALLER_NAME] -i silent -f "[RESPONSE_PATH]\installer.properties"
package.
- [INSTALLER_NAME] is the installer binary.
- [RESPONSE_PATH] is the path where the response file resides.
- Use quotes around directory and pathnames that contain spaces.
- Do not use spaces between VARIABLE=VALUE statements in the response file.
