Quantity computation on points: add a formula
Add a formula
Now the user can add a formula in an already existing session of computation on points.
Step | Action |
1 |
Open the dialogue box corresponding to the command Add a formula:
→ | The dialogue box Add formula will appear |
2 | Choose the desired quantity (1st column) |
→ | The list of components corresponding to the selected quantity will appear in the 2nd column |
3 |
Choose one or more desired components:
→ | The formulas « Flux » corresponding to the selected components will appear in the 3rd column |
4 | Validate by clicking on OK |
![](Images/CalculDeGrandeurSurDesPointsAjouterUneFormule_0.jpg)
Certain limitations
- In the dialogue box Add formula, the quantities already taken into consideration in this calculation entity will not appear.
- Adding of a formula is only possible if the calculation on a point session is closed.
