Function Format
A user-defined function has the following form (in C).
#include "acusim.h"
#include "udf.h"
UDF_PROTOTYPE(usrFunc) ;
Void usrFunc (
UdfHd udfHd, /* Opaque handle for accessing data */
Real* outVec, /* Output vector */
Integer nItems, /* Number of items in outVec */
Integer vecDim /* Vector dimension of outVec */
outVec[0] = ... ;
} /* end of usrFunc() */
- Integer
- Type integer
- Real
- Type floating point
- String
- Type string
- Void
- Type void
- The definitions of symbolic constants, such as UDF_VISCOSITY and UDF_ELM_VELOCITY. These constants are used to access data.
- The prototypes of support routines
- The macro UDF_PROTOTYPE(), which may be used to prototype the user function
In addition, it contains the useful macros min(a,b), max(a,b), and abs(a) for the computation of minimum, maximum, and absolute value of integers or floating point numbers.
The user-function name (generically called usrFunc above) may be any name supported in C that starts with the letters usr. This naming convention avoids any potential conflict in function name space.
This is an opaque handle (pointer) which
contains the necessary information for accessing various data. All supporting routines
require this argument. For example, to access the current time step pass udfHd to the
function udfGetTimeStep(), as in:
This is the resulting vector of the user function. You must fill this vector before returning. On input this array contains all zeros. | ||||||||||||||||||||||||
This is the first dimension of outVec, which
specifies the number of items that needs to be filled. The value of this parameter depends
on command category. In particular:
where the "Number of Elements" is the number of elements in a block, "Number of Nodes" is the number of nodes in a block, "Number of Surfaces" is the number of surfaces in a block, and "Number of Nodal Pairs" is the number of pairs of nodes in a block. |
This is the second dimension of outVec, which
specifies the vector dimension of the particular data. The value of this parameter also
depends on command category. In particular:
#include "acusim.h"
#include "udf.h"
UDF_PROTOTYPE(usrGrav) ;
Void usrGrav (
Integer dir ; /* a running direction index */
Integer elem ; /* a running element index */
Real* usrVals ; /* user values */
udfCheckNumUsrVals( udfHd, 3 ) ; /* check for error */
usrVals = udfGetUsrVals( udfHd ) ; /* get the user vals */
for ( dir = 0 ; dir < vecDim ; dir++ ) {
for ( elem = 0 ; elem < nItems ; elem++ ) {
outVec[elem+dir*nItems] = usrVals[dir] ;
} /* end of usrGrav() */GRAVITY( "my gravity" ) {
type = user_function
user_function = "usrGrav"
user_values = { 0, 0, -9.81 }
}#include "acusim.h"
#include "udf.h"
#define usrGravF usrgravf_ /* FORTRAN name conversion */
Void usrGrav (
usrGravF( outVec, usrVals, &nItems ) ;
} /* end of usrGrav() */ subroutine usrGravF ( grav, usrVals, nElems )
integer nElems
real*8 grav (nElems, 3), usrVals (3)
integer i, j
c
c ... fill in the vector
c
do j = 1, 3
do i = 1, nElems
grav(i,j) = usrVals (j)
enddo
enddo
c
c return
c
return
endNote that you are responsible for Fortran/C name conversion.
