getNbcActor()
Return node actor specified by its information.
Usage
nbcActor = vis.getNbcActor( nbcInfo )
nbcInfo (integer) or (string)
Name or ID of a node.
Return Value
nbcActor (object)
Node actor corresponding to the nbcInfo.
nbcInfo should be valid.
This routine returns the node actor specified by its name or ID which is given by nbcInfo. For example,
nbc = vis.getNbcActor( 1 )
