AcuHeatBalance
Compute the total surface integrated heat flux, surface integrated convective temperature flux and integrated radiation heat flux from an AcuSolve solution database.
acuHeatBalance [options]
AcuSolve Post-Processing Program
AcuHeatBalance is a post-processing utility that uses the AcuSolve solution database to compute the absolute and relative energy balance within the simulation. The energy balance can be computed by summing the surface integrated heat flux values obtained on the walls with the convective temperature flux obtained on the inflow/outflow. The application also reports the integrated temperature, radiation heat flux and mass flux values for the requested element sets.
![](../../images/acusolve/post_processing_programs_acuheatbalance1.png)
Where, is the heat flux and convective temperature flux for the walls and inlets/outlets, respectively. is the total number of surfaces defined with the wall boundary condition (fluid and solid mediums if requested), is the total number of surfaces defined with the inlet boundary condition, and is the total number of surfaces defined with the outlet boundary condition.
Note that for simulations where both fluid and solid element sets are present, the sum of heat flux on the walls will contain contributions from both mediums. This may give the indication that the balance is not close to zero. In this case, only the contribution from the fluid element set should be considered by specifying the -cnns flag appropriately.
AcuHeatBalance can only be used on problems were the steady state solution for the Reynolds Averaged Navier-Stokes is specified. The final value of the steady state run is used for the balance and is written to the output files.
- help or h (boolean)
- If set, the program prints a usage message and exits. The usage message includes all available options, their current values, and the place where each option is set.
- problem or pb (string)
- The name of the problem is specified via this option. This name is used to generate input file names and extracted surface file names.
- run_id or run (integer)
- Number of the run in which the translation is requested. If run_id is set to 0, the last run in the working directory is assumed.
- element_sets or cnns (string)
- Comma-separated list of element_sets. These are the user-given names specified as the user-given name of the ELEMENT_SET commands in the input file. If the element_sets option is set to _all, all output sets are included into the heat balance computation (default).
- periodic or p (boolean)
- If this option is set to TRUE, the application will allow the balance computation to include the contribution of convective temperature flux from surfaces that are specified with the periodic boundary condition.
- query or q (boolean)
- If this option is set to TRUE, the application will run in query mode. Query mode will simply print a list of element sets and associated surfaces that are available for heat balance computation. The list of surfaces is queried from the list of surface_output sets available in the solution database.
- verbose or v (integer)
- Set the verbose level for printing information to the screen. Each higher verbose level prints more information. If verbose is set to 0, or less, only warning and error messages are printed. If verbose is set to 1, basic processing information is printed in addition to warning and error messages. This level is recommended. verbose levels greater than 1 provide information useful only for debugging.
Examples
acuHeatBalance
acuHeatBalance:
acuHeatBalance: Opening the AcuSolve solution data base
acuHeatBalance: Problem <annulus_heat> directory <ACUSIM.DIR> runId <1>
acuHeatBalance:
acuHeatBalance: Successfully Opened Problem: annulus_heat
acuHeatBalance: Successfully Opened Run Id: 1
acuHeatBalance: Found Requested Element Sets from cnns string: 1
acuHeatBalance: Element Set: Fluid Surface Set: ID
acuHeatBalance: Element Set: Fluid Surface Set: Max_Z
acuHeatBalance: Element Set: Fluid Surface Set: Min_Z
acuHeatBalance: Element Set: Fluid Surface Set: OD
acuHeatBalance: Element Set: Fluid Surface Set: Symmetry
acuHeatBalance:
acuHeatBalance: Writing to file: annulus_heat.Individual.Balance.dat
acuHeatBalance: Writing to file: annulus_heat.Total.Balance.dat
acuHeatBalance: Conduction Only
acuHeatBalance: Walls Heat Flux Sum = -0.000120977209668 W
acuHeatBalance:
acuHeatBalance: Program complete
Running AcuHeatBalance produces two output files containing the simulated contribution of heat flux from the requested surface sets called <annulus_heat>.Individual.Balance.dat and <annulus_heat>.Total.Balance.dat.
ElementSet | SurfaceSet | SBCType | Temperature | Heat Flux | Convective Temperature Flux | Mass Flux |
Fluid | ID | wall | 373.0 | -0.15 | 0.0 | 0.0 |
Fluid | Max_Z | symmetry | 0.0 | 0.0 | 0.0 | 0.0 |
Fluid | Min_Z | symmetry | 0.0 | 0.0 | 0.0 | 0.0 |
Fluid | OD | wall | 327.0 | 0.15 | 0.0 | 0.0 |
Temperature Avg | Heat Flux Total | Conv Temp Flux Total | Mass Flux Total |
350 | -1.2E-04 | 0 | 0 |
acuHeatBalance -cnns Fluid
acuHeatBalance:
acuHeatBalance: Problem <channel_laminar_heat> directory <ACUSIM.DIR> runId <1>
acuHeatBalance:
acuHeatBalance: Successfully Opened Problem: channel_laminar_heat
acuHeatBalance: Element Set: Fluid Surface Set: Inlet
acuHeatBalance: Element Set: Fluid Surface Set: Outlet
acuHeatBalance: Element Set: Fluid Surface Set: Symm_MaxZ
acuHeatBalance: Element Set: Fluid Surface Set: Symm_MinY
acuHeatBalance: Element Set: Fluid Surface Set: Symm_MinZ
acuHeatBalance: Element Set: Fluid Surface Set: Wall
acuHeatBalance:
acuHeatBalance: Writing to file: channel_laminar_heat.Individual.Balance.dat
acuHeatBalance: Writing to file: channel_laminar_heat.Total.Balance.dat
acuHeatBalance: Convective Temperature Flux Inlet + Outlet=51.2592664092 W
acuHeatBalance: Walls Heat Flux Sum = -52.0100414952 W
acuHeatBalance: Balance: Convective Flux + Walls Heat Flux = -0.750775086036 W
acuHeatBalance: Percent Difference = 1.46466217453 %
ElementSet | Surface Set | SBC Type | Temperature | Heat Flux | Convective Temperature Flux | MassFlux |
Fluid | Inlet | inflow | 294.5 | 0.8 | -1717.7 | -0.0059 |
Fluid | Outlet | outflow | 303.4 | 0.0 | 1768.9 | 0.0059 |
Fluid | Symm_MaxZ | slip | 0.0 | 0.0 | 0.0 | 0.0000 |
Fluid | Symm_MinY | slip | 293.1 | 0.0 | 0.0 | 0.0000 |
Fluid | Symm_MinZ | slip | 0.0 | 0.0 | 0.0 | 0.0000 |
Fluid | Wall | wall | 348.2 | -52.0 | 0.0 | 0.0000 |
348.15 | -52.0 | 51.2 | 0.0 |
acuHeatBalance -q
acuHeatBalance:
acuHeatBalance: Problem <annulus_heat> directory <ACUSIM.DIR> runId <0>
acuHeatBalance:
acuHeatBalance: Successfully Open Run Id: 1
acuHeatBalance: Total Number of Element Sets: 1
acuHeatBalance: Element Set Name: Fluid
acuHeatBalance:
acuHeatBalance: Total Number of Surface Sets: 5
acuHeatBalance: Surface Set Name: ID
acuHeatBalance: Surface Set Name: Max_Z
acuHeatBalance: Surface Set Name: Min_Z
acuHeatBalance: Surface Set Name: OD
acuHeatBalance: Surface Set Name: Symmetry
acuHeatBalance:
The application will report the amount of heat transfer on a specific surface due to radiation when the radiation_output command is active on a given surface set.
acuHeatBalance –q
acuHeatBalance:
acuHeatBalance: Problem <sphere_radiation> directory <ACUSIM.DIR> runId <0>
acuHeatBalance:
acuHeatBalance: Successfully Opened Problem: sphere_radiation
acuHeatBalance: Found Requested Element Sets from cnns string: 3
acuHeatBalance: Element Set: Inner Surface Set: Inner_Inner_r1
acuHeatBalance: Element Set: Inner Surface Set: Inner_Inner_ri
acuHeatBalance: Element Set: Radiating Surface Set: Inner_Radiating_r1
acuHeatBalance: Element Set: Outer Surface Set: Outer_Outer_r2
acuHeatBalance: Element Set: Outer Surface Set: Outer_Outer_ro
acuHeatBalance: Element Set: Radiating Surface Set: Outer_Radiating_r2
acuHeatBalance: Found Radiation Output in Database
acuHeatBalance: Element Set: Radiating Radiation Surface Set: Inner_Radiating_r1
acuHeatBalance: Element Set: Radiating Radiation Surface Set: Outer_Radiating_r2
acuHeatBalance:
acuHeatBalance: Writing to file: sphere_radiation.Individual.Balance.dat
acuHeatBalance: Writing to file: sphere_radiation.Total.Balance.dat
acuHeatBalance: Conduction + Radiation Only
acuHeatBalance: Radiative Heat Flux Sum = -3.15662873618e-09 W
acuHeatBalance: Walls Heat Flux Sum = 0.00224294477922 W
acuHeatBalance:
Element Set | Surface Set | SBC Type | Temperature | Heat Flux | Convective Temperature Flux | MassFlux | ORI Temperature | ORI HeatFlux |
Inner | Inner_r1 | wall | 578 | -140 | 0.0 | 0.0 | ||
Inner | Inner_ri | wall | 300 | 140 | 0.0 | 0.0 | ||
Radiating | Rad_r1 | wall | 578 | 0.0 | 0.0 | 0.0 | ||
Outer | Outer_r2 | wall | 1035 | 140 | 0.0 | 0.0 | ||
Outer | Outer_ro | wall | 1300 | -140 | 0.0 | 0.0 | ||
Radiating | Rad_r2 | wall | 1035 | 0.0 | 0.0 | 0.0 | ||
Radiating | Rad_r1 | 578 | -140 | |||||
Radiating | Rad_r2 | 1035 | 140 |
