Near-Wall Modeling
For internal wall bounded flows, proper mesh resolution is required in order to calculate the steep gradients of the velocity components, turbulent kinetic energy, dissipation, as well as the temperature.
Furthermore, the first grid locations from the wall and the stretching ratio between subsequent points are also determinant factors that affect solution accuracy. Since boundary layer thickness is reduced as the Reynolds number increases, the computational cost increases for higher Reynolds number flows due to the dense grid requirements near the walls. Additionally, it is hard to determine the first grid locations for complex three dimensional industrial problems without adequate testing and simulation.
For high Reynolds number flows, it is numerically efficient if flows within boundary layers are modeled rather than resolved down to the wall. This suggests that a coarse mesh is used at the expense of numerical accuracy when compared to fully wall resolved approaches.
Wall Function
Figure 1 shows velocity profiles over a flat plate under the zero pressure gradient.
Figure 1. Log-law Velocity Profile
The wall function utilizes the universality of the log-law velocity profile to obtain the wall shear stress. This wall function approach allows the reduction of mesh requirement near the wall as the first mesh location is placed outside the viscous sublayer.
Overall, the log-law based wall model is economical and reasonably accurate in most flow conditions, especially for high Reynolds number flows. However, it tends to display poor performance in situations with low Reynolds number flows, strong body forces (rotational effect, buoyancy effect), and massively separated flows with adverse pressure gradients.
Velocity Profile in the Viscous Sublayer (y+ < 5)
where is the velocity () parallel to the wall, normalized by the friction velocity. The friction velocity is defined as , is the wall shear stress and is the fluid density. is the normalized wall distance (or wall unit). The distance from the wall is and is the fluid dynamic viscosity.
Velocity Profile in the Logarithmic Layer (30 < y+ < 500)
where = 0.4 is the Von Kármán constant and B = 5.5 is a constant.
The wall shear stress can be estimated from the above equation via the iterative solution procedure.
Velocity Profile in the Buffer Layer (5 < y+ < 30)
Since two equations mentioned before are not valid in the buffer layer a special function is needed to bridge the viscous sublayer and the logarithmic layer. Details are not covered here.
Kinematic Eddy Viscosity
The kinematic eddy viscosity can be obtained as .
Two Layer Wall Model
The two equation turbulence models based on eddy frequency (ω) and the Spalart-Allmaras (SA) model do not require special wall treatments to solve the boundary layer as these models are valid through the viscous sub layer.
- is the Von Kármán constant,
- = 5.08 (Chen and Patel, 1988).
- = 70.
