Launch a Simulation via Windows Terminal
Launch with CMD
Launch with PowerShell
nanoFluidX auxiliaries (nanoFluidX[c], nanoFluidX[p], nanoFluidX[m])
The script set_nFX_environment.bat/.ps1 also sets the
environment for the nanoFluidX auxiliaries and they
can be run through nanoFluidX[c], nanoFluidX[p], and nanoFluidX[m] (no need for
.exe extension) and passing the relevant options. For
example:
nFXc --nfx nfxccase.cfgnFXp -i case.cfgnFXm -f PATH
