NFX-T: 1000 Simple Gearbox
Set up a simple multiphase gearbox for drive train oiling simulation using SimLab for CFD-nanoFluidX solution. Oil distribution will be analyzed and torques and forces will be computed.
- Select unit system
- Import CAD geometry (*.x_b)
- Define SPH flow solution
- Prepare the geometry for simulation
- Assign materials
- Define domain (gravity)
- Assign motion
- Create reference node for fluid volume
- Perform one-click SPH particles creation
- Review conflicting fluid particles
- Set solver settings and result requests
- Data check
- Export particle and configuration files
- Save a SimLab database (*.slb)
62.5 mm
(Output_Gear) and 20.0 mm (Input_Gear). We will create a
1.0 sec multiphase simulation at a resolution of
1.0 mm. Input speed will be 1000 rpm.
Multiphase
- Physical time:
1.0s - Resolution:
1.0mm - No. of particles:
1.3M - Pre-processing: <
10min - 1x NVIDIA Tesla V100:
30min
Prerequisites
To run this simulation, you will need access to a licensed version of SimLab and nanoFluidX.
Model Files
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
