Viscosity-Temperature Coupling
This section describes the parameters for properly modeling viscosity-temperature coupling.
viscTempModels
viscTemp_model
phase_affected 1
viscTemp_model POLYNOMIAL
poly_coeffs1 0.0
poly_coeffs2 0.0
poly_coeffs3 0.0
poly_coeffs4 0.0
poly_coeffs5 0.0
viscTemp_model
phase_affected 1
viscTemp_model SUTHERLAND
sutherland_refVisc 0.1
sutherland_refTemp 273.15
sutherland_coefficient 12.01
viscTemp_model
phase_affected 1
viscTemp_model POWER_LAW
power_refVisc 1.716e-5
power_refTemp 273.15
power_exponent 0.666
- phase_affected
- Similar to the phase_motion command, this option tells you which phase is affected by this viscosity-temperature dependence model.
- viscTemp_model
- Model according to which the viscosity will be calculated as a function of temperature.
- poly_coeffs1, poly_coeffs2, poly_coeffs3, poly_coeffs4, and poly_coeffs5
- Polynomial coefficients for the polynomial viscosity-temperature model.
- sutherland_refVisc
- Sutherland reference viscosity.
- sutherland_refTemp
- Sutherland reference temperature
- sutherland_coefficient
- Sutherland coefficient
- power_refVisc
- Power law reference viscosity
- power_refTemp
- Power law reference temperature
- power_coefficient
- Power law exponent
