Learn how to perform a DOE study using HyperStudy and the HyperStudy Job Launcher within HyperMesh. HyperMorph is used to parameterize the shape of the design.
In this step you will: define the hypothesis on the elements; create isotropic materials, shell properties, and loads
and load cases; assign properties and materials to elements; and export the model.
Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
HM-4850: Introduction to Samcef
In this step you will: define the hypothesis on the elements; create isotropic materials, shell properties, and loads and load cases; assign properties and materials to elements; and export the model.
