HM-4400: Explore the ANSYS Interface
In this tutorial you will learn about HyperMesh’s ANSYS FE input reader, template, macro menu, and user profile.
Tools Overview
In this section you will learn about ANSYS FE-input reader, ANSYS Template, ANSYS Utility menu, ANSYS Interface Online Help, ANSYS User Profile, Model Import, and Model Export.
ANSYS FE Input Reader
ANSYS Solver is one of the leading software products in the computer aided engineering (CAE) field. This software is used to simulate designs in general engineering and aerospace industries. ANSYS has the capability to solve structural, thermal, and fluid models. Different analysis like static structural, dynamic, modal, harmonic, buckling, spectrum, steady state and transient thermal, and radiation can be solved. Both linear and non-linear analysis are supported by ANSYS.
HyperWorks has recognized ANSYS as one of the major Solvers available in the current CAE field. HyperWorks has extended its support to ANSYS Solver by recognizing its element types, solution methods, and file formats. You get benefits from using both HyperWorks tools and ANSYS Solver. During pre-processing of the model, you can define ANSYS elements and apply loads and boundary conditions that can be read by ANSYS. Once the analysis is done in ANSYS, both deck and result files can be read back in HyperMesh and HyperView. You can post-process the results of the analysis solved by ANSYS.
ANSYS Solver writes analysis model data in the form of a script file. It also writes the model in binary file format. HyperMesh and HyperView can read the model data written in script format. These files are saved with file extension .cdb. Newer versions of ANSYS use BLOCK format to write their model data in script file. HyperMesh and HyperView can transfer the ANSYS model data into HyperMesh.
ANSYS Solver writes model data in BLOCK format. Older versions of ANSYS (ANSYS 5.4 or earlier) uses APDL format.HyperMesh can read both types.
ANSYS Utility menu
To open the ANSYS Utility menu, click from the menu bar. The ANSYS Utility menu contains the following macros and tools.
- Surface Manager
- Generates thermal, radiosity, and structural surface elements. The Ansys Surface Manager dialog has simple steps to create surface elements over base geometry elements.
- Convert to Special 2nd Order Macro
- Convert fully second order elements to special second order elements.
- Update Pre 8.0 HM Model
- Updates old .hm files, prior to 70-SA2-043 update, to .hm 8.0 files.
Import Tab
Access the Import tab by clicking menu bar.
from the![](../../../images/tutorials/hm/hm_4400_import_tab.png)
Hover over each option to learn more.
Export Tab
Access the Export tab by clicking menu bar.
from the![](../../../images/tutorials/hm/hm_4400_export_tab.png)
Load the ANSYS User Profile
In this step, you will load the ANSYS user profile in HyperMesh.
Import a Model
In this step, you will import an ANSYS deck written by the ANSYS Solver.
![](../../../images/tutorials/hm/hm_4400_importing_tuning_fork_model.png)
Figure 4.
Export the Model
In this step, you will export a ANSYS model from HyperMesh.
