Container Entity Toolbar
The Container Entity toolbar provides you quick access to the System/Assembly, Analysis, and Command Sets panels.
Figure 1. Container Entity Toolbar
| System/Assemby | Allows you to create and save systems/assemblies, to modify system/assembly attachments, and to set system options and initial conditions. | |
| Analysis | Allows you to create and save an analysis, to modify analysis attachments, and to set analysis options and initial conditions. | |
| Command Sets | Allows you to create command sets for the solver-command file. The command sets for a model are order dependent since they define the contents of the solver command file. |
