/ALE/GRID/DISP
Block Format Keyword The displacement of a grid node depends on the displacements of the neighboring grid nodes.
/ALE/GRID/DISP | |||||||||
Umax | |||||||||
Vmin |
Field | Contents | Si Unit Example |
Umax | Maximum absolute grid
velocity. Default = -1030 (Real) |
Vmin | Elements with a volume
less than Vmin will
be deleted. Default = -1030 (Real) |
- Grid nodes displacement depends
on the displacement of the neighboring nodes based on the following
equation:
(1) - Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
