Block Format Keyword Grid nodes are connected with nonlinear springs
(those springs have no effect on the material, only on the movement of the
grid).
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| /ALE/GRID/SPRING |
| Vmin |
| Field |
Contents |
SI Unit Example |
Typical time
step (Real)
Nonlinearity
factor Default = 0.0 (Real)
Damping
coefficient Default = 0.5 (Real)
Shear factor Default =
1.0 (Real)
| Vmin |
Element with a volume less
than Vmin will be
declared Default = -1030 (Real)
- This option is available for 3D
analysis only.
- Further explanation about this
formulation can be found in ALE Formulation in the Radioss Theory Manual.
- Effective time step
is computed using damping parameter:(1)
