Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup
during the computation.
Engine Keyword An ALE link definition /ALE/LINK/VEL (Starter) which was deactivated during a previous Engine run can be activated again with this keyword.
Engine Keyword With ALE links on grid velocities, given nodes are linked to the given main grid velocities. You can specify the direction
or a combination of directions. This definition is only taken into account during the current run.
Engine Keyword This option defines the numerical method for internal force integration. This is relevant only for brick element and
the ALE legacy solver (momentum equation solved with FEM).
Generates animation files containing results according to the keywords specified. The keywords are specified in the
topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling
or quasi-static), different options to control the implicit computation, different implicit time step method and
implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF)
and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature,
etc.) in state file (STA-File).
are linked to the given main grid velocities. You can specify the direction or a combination
run.
/ALE/LINK/VEL/Iform/Keyword3/Keyword5
node_ID1, node_ID2
ID1, ...,
IDn
Field
Contents
SI Unit Example
Iform
Formulation flag.
= 0 (linear)
= 1 (maximum)
if
if
= -1 (minimum)
if
if
(Integer)
Keyword3
A combination of X, Y, and
Z:
X, Y, Z, XY, XZ, and XYZ
Keyword5
GRNOD or
NODES defines the way to provide secondary
nodes.
node_ID1
First main node
number.
node_ID2
Second main node
number.
IDi
Secondary node or node
group identifiers (depending on Keyword5)
Using formulation
Iform=0 requires an ordered node list. Using
Iform=0 with
Keyword5=GRNOD also requires an unsortable
node group (refer to /GRNOD/NODENS).
Radioss will superimpose the grid velocities if different ALE links are defined in both
Starter and Engine for the same node.
