/GRNOD/SUBMODEL
Block Format Keyword Describes the node groups which are selected from submodels.
Enter selected item numbers (any number may be input, 10 per Line)
/GRNOD/SUBMODEL/grnd_ID/unit_ID
grnd_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
Field Contents SI Unit Examples
grnd_ID Node group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grnd_title Node group title
item_ID1, item_ID2,..., item_IDn List of submodel identifiers
(Integer)
  1. Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
  2. If item_ID is a positive SUBMODEL id number, all nodes associated with the referenced submodel group are added to the node group.
  3. If item_ID is a negative SUBMODEL id number, the nodes associated with the referenced submodel group are deleted from the node group.
