/GRQUAD/BOX or /GRQUAD/BOX2
Block Format Keyword Describes the quad groups are inside the box.
| /GRQUAD/BOX/grquad_ID/unit_ID or /GRQUAD/BOX2/grquad_ID/unit_ID | |||||||||
| grquad_title | |||||||||
| box_ID | |||||||||
| grquad_ID | Quad group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grquad_title | Quad group title (Character, maximum 100 characters) |
| box_ID | Box identifier, which is
defined in Boxes (Integer, maximum 10 digits) |
- If type is
BOX, all elements having all nodes inside the box or on its
surface are selected.
If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
