Solid-Shell Elements (/PROP/TSHELL)
The elements HA8, HEPH and BRICK20 can be transformed to solid-shell elements by setting constant the normal stress through the thickness.
![](../../../images/solvers/element_solid-vs-shell.png)
Figure 1. Solid versus Solid-Shell
Mesh | Element Name | Number of Integration Points | Hourglass Formulation |
HSEPH | Inplane: 1 In thickness: up to 9 |
Physical stabilization |
HA8 | From 2x2x2 to 9x9x9 | --- | |
PA6 | Inplane: 1 In thickness: up to 9 |
SHELL16 | Inplane: 3x3 or 2x2 In thickness: up to 9 |
![](../../../images/solvers/element_application.png)
Figure 2. Application of Solid-Shell Elements
