Solid to SPH Option (Sol2SPH)
The solid to SPH option (Sol2SPH) enables you to turn a solid element into particles in order to increase the time step/robustness of a Lagrangian calculation, while not significantly changing the physics.
- Isolid = 1, 2 or 24
- Iframe = 1 or 2
- 8-node bricks (/BRICK including degenerated) and 4-node tetras (TETRA4), but not 10-node tetras.
/PROP/SOLID/3
Prop example
# Isolid Ismstr Icpre Itetra10 Inpts Itetra4 Iframe dn
1 2 0 0 0 0 1 0
# q_a q_b h LAMBDA_V MU_V
0 0 0 0 0
# dt_min istrain IHKT
0 0 0
# Ndir SPH_part
1 10
- SPH_part
- Part number defining the SPH properties
- Ndir
- Number of particles created for each direction, the maximum value is 9
Ndir = 1: 1 particle is created | Ndir = 2: 8 particles are created | Ndir = 3: 27 particles are created | Ndir = 4: 64 particles are created |
Ndir = 1: 1 particle is created | Ndir = 2: 4 particles are created | Ndir = 3: 10 particles are created | Ndir = 4: 22 particles are created |
The transition from solid elements to SPH particles can be triggered by contact or by brick deletion.
