The properties required to define the spring characteristics are stiffness
and damping
. Nonlinear and elasto-plastic properties can also be applied,
for all degrees of freedom. The properties are of the same form as simple TYPE4 spring
elements (One Degree of Freedom Spring Elements (TYPE4)).
See Linear Spring; the explanation is the same as for spring TYPE4.
