Altair Inspire Extrude User Guide
2022.1
  1. Home
  2. Inspire Extrude Metal
    Get started with Inspire Extrude Metal.
  3. FAQs
    Find answers to Frequently Asked Questions from our users.
  4. General Questions
  • What's New
  • Get Started
  • Training
  • Inspire Extrude Metal
  • Inspire Extrude Polymer
  • Inspire Friction Stir Welding
  • Inspire Resin Transfer Molding
  • Parametric Modeling
Index
2022.1
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire Extrude? Learn the basics here.
  • Training
    Explore Altair's resources for training and support.
    • What is Inspire Extrude Metal?
      Inspire Extrude Metal offers an analysis tool for virtual testing, validation, correction and optimization of extrusion die designs.
    • FAQs
      • General Questions
        • How Do I Exit a Tool?
        • What CAD Files Are Supported by Altair Inspire Extrude?
        • What Languages Are Supported by Altair Inspire Extrude?
        • What Defects Can Be Identified Using Altair Inspire Extrude?
        • What Results Are Provided by Altair Inspire Extrude?
        • Can Altair Inspire Extrude Predict Tool Deformation and Stresses?
        • Are Multiple Packages of Altair Inspire Extrude Needed for Different Materials and Different Extrusion Processes?
        • Which Platforms Does Altair Inspire Extrude Run On?
        • What Processing Parameters Are Required to Run Altair Inspire Extrude?
        • What Extrusion Presses Are Supported By Altair Inspire Extrude?
        • How Do I Change Units in Altair Inspire Extrude?
        • Is it Possible to Add or Modify Materials in Altair Inspire Extrude?
        • Can I Optimize Bearing Lengths Using Altair Inspire Extrude?
        • Can I Control the Size of the H3D file?
        • What Are the Recommended Values for MemorySolver and ReservedMemorySize?
        • What is the Bearing in a Metal Extrusion Die?
        • What Types of Indirect Extrusion are Supported by HyperXtrude?
        • How do I use Temperature Dependent Stress Strain Data for Tool Deflection Analysis?
        • How Do I Save Solver Temporary Files to a Different File?
        • What Files are Needed from the Altair Inspire Extrude Run Folder?
      • Simulation
      • Troubleshooting
    • Extrusion Analysis
      Setup and perform an Extrusion analysis.
    • Tool Deflection Analysis
      Setup and perform a Tool Deflection analysis.
    • Quenching Analysis
      Setup and perform a quenching analysis.
    • Reference
      Find information about material data blocks in GRF files.
    • Tutorials
      Start using Inspire Extrude with our interactive tutorials.
    Get started with Inspire Extrude Polymer.
    Get started with Inspire Friction Stir Welding.
    Get started with Inspire Resin Transfer Molding.
    Create 2D sketches, surfaces, and solids.
2022.1
  1. Home
  3. FAQs
  • What's New
  • Get Started
  • Training
Index
General Questions
(c) Altair Engineering, Inc. All rights reserved.
