Altair Inspire Extrude User Guide
2022.1
  1. Home
  2. Inspire Extrude Metal
    Get started with Inspire Extrude Metal.
  3. FAQs
    Find answers to Frequently Asked Questions from our users.
  4. Simulation
  • What's New
  • Get Started
  • Training
  • Inspire Extrude Metal
  • Inspire Extrude Polymer
  • Inspire Friction Stir Welding
  • Inspire Resin Transfer Molding
  • Parametric Modeling
Index
2022.1
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire Extrude? Learn the basics here.
  • Training
    Explore Altair's resources for training and support.
    • What is Inspire Extrude Metal?
      Inspire Extrude Metal offers an analysis tool for virtual testing, validation, correction and optimization of extrusion die designs.
    • FAQs
      • General Questions
      • Simulation
        • How Can I Reduce CPU Time and Get a Quick Solution?
        • How Do I Simulate Dead Cycle Time?
        • How Do I Use Existing Mesh in Altair Inspire Extrude?
        • How Are Symmetric Models Handled?
        • How Do I Account for Mandrel Offset in Simulation?
        • How Do I Calculate Particle Traces Using Inspire Extrude?
        • How do I Define (time) Variable (HTC) Heat Transfer Coefficient?
        • How Can I Define Material Properties Data as Function?
        • How Do I Set Variable Time Steps?
        • What are the Differences Between Bonded, Contacting and No Contact Tool Deflection?
        • How Should I Specify the Billet Axial Taper?
        • How Do I Handle Models with Variable Bearing Start Location?
        • How Can I Output Strain in Tool Deflection Simulation?
        • What are Key pset Solver Variables?
      • Troubleshooting
    • Extrusion Analysis
      Setup and perform an Extrusion analysis.
    • Tool Deflection Analysis
      Setup and perform a Tool Deflection analysis.
    • Quenching Analysis
      Setup and perform a quenching analysis.
    • Reference
      Find information about material data blocks in GRF files.
    • Tutorials
      Start using Inspire Extrude with our interactive tutorials.
    Get started with Inspire Extrude Polymer.
    Get started with Inspire Friction Stir Welding.
    Get started with Inspire Resin Transfer Molding.
    Create 2D sketches, surfaces, and solids.
2022.1
  1. Home
  3. FAQs
  4. Simulation
  • What's New
  • Get Started
  • Training
Index
Simulation
(c) Altair Engineering, Inc. All rights reserved.
