DXF
PollEx PCB supports DXF file such as *.dxf file.
Explode: Separate sub objects of DXF.
Layer Merge: Merges multiple divided layers of DXF into one.
View new features for PollEx 2022.1.
Discover PollEx functionality with interactive tutorials.
PollEx BOM is a BOM parsing and formatting tool
Use PollEx CAM to handle any type of Gerber, such as 274D or 274X, convert 274D to 274X type, and compare each revision data.
The Component Arrangement Plan function replaces a paper worksheet with a graphic display report that shows on-board components with their area and marking at first pin.
PollEx Cross Probe (CP) supports two checking types, Same Type Check/Compare and Link and Search.
PollEx Golden Sample generates guide documents automatically.
Use PollEx Logic to import and view schematic sheets, designs, check symbols, nets, and object properties.
PollEx suite is a knowledge-based design-verification toolset for PCB.
Explore the PollEx PCB interface.
The PollEx PCB tool bar contains frequently used menus.
View controls enable you to control the view and display of your model in the modeling window.
Use the File menu to check basic functions, import ECAD files into PollEx PCB, and export working design to 3rd party EDA vendor formats.
Import ASCII files from ECAD vendors.
PollEx PCB supports various Altium’s PCAD, Protel, and Designer files.
PollEx PCB supports CADVANCE files such as *.dsn, *.dbg, and *.dbr files.
PollEx PCB supports EAGLE CAD file such as *.brd file.
Mentor Graphics is releasing several different ECAD tools, PADS PowerPCB, Board Station, and Xpedition.
PollEx PCB supports various Zuken’s CAD design files: Cadstar, Board Designer, and PWS.
PollEx PCB supports IPC-2581 file such as *.cvg file.
PollEx PCB supports CAM350 file such as *.CAM file.
PollEx PCB supports four types of GERBER formats: 274X, 274D, Drill, and Square Hole.
Under the setting menu, there are many settings for defining default value for using PollEx PCB. Use the menus under Setting in main menu.
Use the View menu to control the display more efficiently.
Using Properties menu, you can see and edit properties of objects on board or library link.
Under the Tools menu, there are many useful functions. Almost functions help you to get documents or reports for nets or components.
Refer to each individual user guide for the analysis products.
PollEx PCB supports different viewers for reviewing objects on board.
Refer to each individual manual for the manufacturing products.
Redmark is a function to make comments in the design. This function can be used to leave messages or comments to assign tasks.
In Redmark+, it is enabled to get the upgrade features for mark-up tools such as drawing object, text, measurement and reply, history, and so on.
Definition for meta character using in making sentence for searching option.
