Fuse
This item tracks the voltage and signal lines in the circuit, calculates the voltage value of each net, and checks whether the all fuse connected to the net is within the allowable voltage range.
- Component: Select Fuse component group to be checked.
- Power Net: Select power net group to which Fuse components are connected.
- Working Voltage
Check: Set the allowable working voltage of this component. You can set this
by entering the allowable value directly or select the property name which
contain allowable working voltage value. You can also assign tolerance of
this check.
Stress Test Option
Set whether passive components are considered short or open when navigating signals and power lines.
