Process Setting
Create and manage the process of the design project.
- • Link with corporate system
- PLM Transfer: Set whether to use transferring to PLM function.
- EO Transfer: Set whether to use EO transfer function.
- Manage process
- Add: Add a new process.
- Delete: Delete the selected process.
- Import settings: Import a process template automatically. The template is imported according to the status, product name and type of the project. If there is no templated matched with the project, no template is imported.
- Specify a project for each process
- Click
to select and specify a project
leader. - As the same way, specify the project leader for each step. If the
project leader of all processes is same, click
to set it in batches.
- Click
