Export the Installation Configuration
Export cluster, profile and application definition information to a zip file.
Create a zip file containing cluster, job profile and application definition information. The zip file can then be used to install Access Desktop on other workstations eliminating the need to add clusters, job profiles and application definitions at each workstation.
  1. Open the Windows system tray.
  2. Double-click the Access Desktop icon .
  3. Click .
  4. Select Export Config from the menu.
  5. Select a folder where the exported configuration will be saved.
    A zip file called AltairAccessConfig.zip is created in the selected folder.
