Delete Job Files
Delete job files from the Job Input or Ouput.
Click the Jobs tab located in the upper left-hand of the page.
The job monitoring page is displayed with the list of the jobs that is submitted to a cluster.
Perform one of the following options:
- Click the job name from the list.
- Select the job name from the list and click the View Details from the context menu.
The job summary page is displayed.
Figure 1. Job SummaryNote: Based on the job status, the job tab is enabled. If the job selected is completed, then the Output tab is enabled. If the job selected is in running state, then the Running Folder tab is enabled. -
Choose one of the following options:
- Click Running Folder tab if you want to view the files of a running job.
- Click Output tab to view the result files of a completed job.
Select a file by clicking the check-box next to the file name.
Tip: You can also select multiple file to delete.
- Right click and select Delete from the context menu.
- Click
located in the upper right-hand of the
page.
Click Yes.
The job will be terminated.
