Search for an Action in Audit Log
Search for an action and its details by using an username or an action attribute type.
You can search the audit log by using an username or an action attribute type and export the data.
  1. Click .
  2. Select Audit Logs.
    Audit User Activity page is displayed.
    Audit User Activity
    Figure 1. Audit User Activity
  3. Enter your search criteria and press Enter.
    Search Criteria
    Figure 2. Search Criteria
    Note: You can search an audit log data using username or action attribute type.
    For example, if you have searched for an audit log data using the action attribute type job then the following page is displayed:
    Search Result
    Figure 3. Search Result
