Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
You can generate animations from the Job Summary tab in the Plot viewer.
From the Job Summary tab, you can select result files to visualize plots and
animations by selecting the parameters from the TOC. You can download the animation
result to your local system and view it in HyperView Player.
In the Jobs tab, click a job to view its summary.
The Summary tab is displayed. By default, the
contents of the job output file is displayed in the Text
viewer. Figure 1. Summary Tab
Select a result file from the File drop down list.
The contents of the result file is displayed in the
Text viewer and the Plot
viewer is displayed.
Click the Plot viewer.
The plot TOC is displayed.
Click Animation.
The animation TOC is displayed. Figure 2. Animation TOC
Optional: Deselect Use Result File and click to select other model file from a remote file
browser location.
Optional: Click Subcase and select the required load case.
Note: Choosing the Subcase is optional. By default, the first entry in the
Subcase list is considered for an animation.
Optional: Click Simulation to select simulation query.
Figure 3. Animation Simulation Query Menu
Select the following in the Simulation Query:
Select Filter
Select Start, End, and Step values.
By default only 100 time steps are available for the view. Click
Refresh link, to view the complete list of Time
Steps.
Note: Setting the Simulation Query is optional. By
default, all the listed simulations in the Simulation
Query is considered for an animation.
Click OK.
Select the required options for the Model and
Result Type, the corresponding
Component Contour is preselected.
Optional: Click , to specify the compression ratio for
the animation file.
Click Animate.
A message to download the HyperView Player is displayed. Figure 4. HyperView Player Download Link
The animation results can be viewed from the HyperView Player application.
Tip: The Back link takes you back to the TOC pop-up
screen for the animation where you can modify the animation
parameters.
Click . The results are downloaded and
displayed in the HyperView Player application.
Optional: Click the hyperlink to download the HyperView Player software. The Altair
HyperWorks web page is displayed with the HyperView player 2021.1 software to
download.
