LT Card
This card assigns a resistor, inductor or capacitor in series to a voxel mesh for the finite difference time domain (FDTD) method.
On the Source/Load tab, in the Loads /
networks group, click the
Load icon. From the drop-down list, click the
Port load (LT) icon.
Figure 1. The LT - Generic load on a port dialog.
Parameters:
- Define/replace a load at the given port
- Define a load or replace a load at the given port with the parameters specified below.
- Remove all LT type loads previously defined
- This LT card does not define a load, but rather all previously defined LT loads are deleted. All the other input parameters of this card are ignored.
- Load name
- The name of the load.
- Name of port definition
- The name of the port.
- Discrete element
- A single resistor, inductor or capacitor is added to the port.
- Complex impedance
- The real and imaginary part of the complex impedance in .
- Series circuit
- The resistor value in , inductor value in Henry and the capacitor value in Farad to be added as a series circuit.
- Parallel circuit
- The resistor value in , inductor value in Henry and the capacitor value in Farad to be added as a parallel circuit.
- Resistor value (Ohm)
- Value of the resistor in .
